Where is it ? my fitter said he couldn't see one....inside the TB ?Some cars use pressure sensors instead... A map sensor. However I am fairly... No I am certain the 1.4 still use a tb maf m8
OK Chris thanks for that, I don't do nuffin myself, I'll let my fitter know. I was going to change it if the tps didn't cure my stuttering engine. He did say if I had one he would just clean It first.Throttle body. Look down the throttle body... Do you see the little bridge going from one side to the other... That's it.
Get a new fitterOK Chris thanks for that, I don't do nuffin myself, I'll let my fitter know. I was going to change it if the tps didn't cure my stuttering engine. He did say if I had one he would just clean It first.
No, not like that, only stuttered when slamming the pedal to the metal, h701 suggested the tps a while back but I have only just got round to it, seems fixed now.....crossed fingers and all that.Stuttering sounds like the maf dry solder issue no? Floods on acceleration then stutters... Clears fuel then okay.. Repeat process?
Oh I thought u said it didn't fix it. My brain does not work apparentlyNo, not like that, only stuttered when slamming the pedal to the metal, h701 suggested the tps a while back but I have only just got round to it, seems fixed now.....crossed fingers and all that.
Just a simple question. Does the 1.4 facelift, coilpack, 52 plate have a maf ?????
My fitter said no !!!
