My 1.0 2001MY idles high or goes from low to high (700 to 1600 rpm) when the engine reaches normal temperature.
I have goggled to sort the problem but:
Haynes manual refers “check voltage between terminals 2 and 3 on the airflow meter wiring connector” - How can I identify these terminals, as I see no numbers there.
The lambda sensor must read from o.4 to o.6v, measured in the middle wire, but I have the 4 wire sensor, I think I must use the black wire.
Thanks for your help,
Mário
Mário
