MA12 parts last chance from an old timer
Parts for sale; that have been in storage since 2017. The original post is here:
https://www.micra.org.uk/threads/k10-parts-reconditioned-modified-and-spare.68284/. But todays post below:
Available for two weeks only on here first.
Can post at buyers cost
Collection welcomed
Will split most parts (except for nitrous related...these stay together)
Please bid a price for any parts of interest. Don't be shy, you might be pleasantly surprised at how much of a bargain you can make here :)
MA12 Head* (Non-EGR) This head has had two previous skims during its lifetime
Complete with:
-Relieved and smoothed external ports to match stock gaskets (including EGR restriction on Exhaust port 2)
-Relieved and smoothed internal ports (including around the spark plug ports)
-Port-Matched Inlet manifold included (requires PCV)
-New Timing belt included
-Valves lapped-in
-All gasket surfaces hand-stoned
-New head gasket included
-New Exhaust Manifold Gaskets included
-New Rocker Cover Gasket included
-New Thermostat housing gaskets included
-New Carburetor face gaskets included
*Requires a pair of locking clips for the rocker shaft*.....or some decent other anti rotation such as thread locking compound for example
MA12 Engine block
In My Opinion Requires 1st oversize re-bore (Separately will cost Approx. £100)
In My Opinion Requires 1st oversize piston & rings set (Separately will cost Approx. £200)
'Magnacore' Ignition lead set
K&N Air filter Element (fits stock air filter housing)
Nitrous Gear:
-Modified MA10/MA12 Carburetor plate (to accept Wizards of NOS crossfire nitrous and fuel mixing injector):
Wizards of NOS parts:
-Nitrous controller computer (Max Extreme)
-11lb nitrous bottle (empty) complete with:
--Aluminum billet valve
--Bottle mounted; Safety Pressure Relief Valve (SPRV)
--Bottle heater
--Aluminum quick release mounting bracket
-Nitrous-Pulsoid (blue) fitted with 50-shot jet (+25bhp power adder)
-Fuel Pulsoid (red) fitted with jet matched with the above nitrous jet on MA series mechanical fuel pump
-Crossfire Nitrous and fuel mixing injector
-Fuel Take-off Tee
-System Arm/Disarm aircraft switch with red safety cover
Yee-haa and best-regards
Old-timer Richard
