Ma10s Carb dcz 306
Hey!!, i own a nissan k10 1983 model and its wiring connection to the carb has been jumbled by the previous users ( some wires are disconnected). Anybody have the wiring diagram for the carb? As i believe its not electronically controlled carb, but has 7 or 8 wire connections. I even discovered disconnected electric clutch switch in the clutch pedal. Wonder what kind of a wiring was used for this carb. please help.
Theyre fairly simple to wire up
There's not a lot of info on carb wiring
You should have
Anti-dieseling valve & Idle-up valve
Usually there's more for the auto choke but yours will be manual for an 83
Thank you for the feedback :) i have found the 1987 service manual but im not quite sure both 1983 and 1987 prefer the same carb or wiring system. And what about the engine rev. unit?
I read this first at 5am and couldn't understand a word of it :p
Anyway... that wiring is a later diagram as it has a few items that yours won't. The biggest difference being the auto-choke
I'll dig uo a diagram from my manuals for yours :)
