Mark
couple of questions I wanted to ask regarding the MA10 and 12 engines,
what are the actual differences? are they exactly the same apart from the bore and stroke? I know the two camshafts are slightly differant but thats about it,
the standard max torque figures are quite low standard, 3200 and 3600, is there any reason for this? could this be down to the inlet manifold? or even the camshaft? I have read somewhere that the standard camshaft is only 235 duration, which i thought was quite low, I am replacing my cam for a 270 duration cam any ideas if the peak torque figures are likely to be higher up within the rev range?
