Ma10/12 gasket kits
pork
I've got an ma10 engine, but want to put the ma12 head on it (told it fits!!)
But there are 2 sets, 1 each for the ma10 and ma12
Are they interchangeable ?
I thought both engines a identical apart from the ma12 has a longer stroke
Sent from my iPad using Tapatalk
Not sure? Il have a look, I remember speaking to dave from Dw engineering about the ma10 heads and what can be done with them, and he said to bin it and put on the ma12 as it has bigger inlets :)
According to Wikipedia, ma10 is 68 mm, and ma12 is 71 mm
Do you think I should use the ma12 kit then?
if its more than 68mm you will have exposed fire-rings when using an ma10 h/g, if its less then i would use an ma10 one personally mate
Cheers mate,
Found a load of old posts just now whilst looking or my old topic about the heads, and says wat you said :)
Hey pork have you a 1.2 head fitted to youre 1.0?:)
