less than 50 mm would it need one? and do you know how i the easiest way to remove the bump strips on the side is?
I haven't replaced my panhard rod yet, down about 120mm. I wouldn't worry too much yet unless you're fitting wide wheels.
Bump strips? Hmm, heat then up pretty well then slowly peel them away. Too fast or too cool and it'll pull paint off. Use a toffee wheel to remove the glue stuff. Or WD40/Polish and some elbow grease
if the bushes are,nt seizedEasy to fit
just measure the aount of wheel tuck on both sideshow do you adjust them correctly?
frank said:if the bushes are,nt seized
