M micka Apr 12, 2009 #1 i had to angle grind my arches on the rear inner lip, what do i use to protect it from rusting as there is bare metal on the inner arches where i cut the lip? any help will be appreciated, thanks.
OP OP M micka Apr 12, 2009 #3 will underseal just cause it to rust under it? what about wax oil, is wax oil permanent? im still learning.
joesouthgate Super Moderator Moderator Club Member Apr 12, 2009 #4 wax oil is basicly underseal. sand it and spray it would be best.
OP OP M micka Apr 13, 2009 #5 hammerite should be ok my dad recons as its thick and will seal the lip nicely, any suggestions?
Robb Site Supporter Apr 14, 2009 #6 Should be fine, if in doubt put everything on, rust stop, paint, waxoyl
