Lots of K11 Parts for sale (plus other random stuff)
SuperUno
Buy & Sell Member
Having a big clearout of micra parts which are currently hiding under my work bench!
All on here a few days before they start getting listed on fleabay.
Where it says 'No Post' it means it ! These are collect / deliver from Uxbridge / Aylesbury areas, or i do travel around a lot for work, so i MAY be able to deliver to you. But check BEFORE buying!
All items can be collected / delivered to save postage costs.
Item Description Price P&P Total
Indicator stalk Used, very clean part no NILES 14509 £10.00 Free £ 10.00
GA16 Fuel Rail (side feed) Used in v clean condition £ 5.00 £ 3.99 £ 8.99
Locking wire 0.25KG 0.81mm Annealed Stainless steel Spec DTD189A - Brand new £ 10.00 £ 2.99 £ 12.99
Ford 1.6, 1.8 & 2.0 Zetec Engine Training Manual 11/92 Code 00/209 Works training manual on the zetec engine - complete with wiring diagrams, everything for a rebuild. In good condition, bit faded cover, and pages a bit turned up at edge. £ 4.99 Free £ 4.99
CGA3 Head Comes complete with valves - all from a working engine £ 10.00 No Post £ 10.00
Coilpack 'later' inlet manifold For the later type throttle body and sidefeed injectors - in good condition £ 5.00 No Post £ 5.00
K11 Micra Coil pack engine - cam position sensor Came off a working engine £ 5.00 Free £ 5.00
CGA3 Flywheel Came off a working engine £ 5.00 No Post £ 5.00
K11 Micra Coilpack engine exhaust manifold & lambda Came off a working engine, complete with lambda sensor (4 pin) £ 10.00 No Post £ 10.00
K11 CGA Thermostat and housing Complete thermostat and housing off a working engine £ 10.00 Free £ 10.00
SATA to USB Controller kit Brand new, used once only, complete with power supply kit. £ 4.99 £ 2.00 £ 6.99
Any questions or want more info then PM me. Pics of all items will soon be available.
I will be traveling through there late afternoon , early evening of May 16th. Could arrange to meet up near my route through.
I will try and get pics up either tonight, or tomorrow night.
Got to try and re-wire a Grande Punto today..... :confused:
Gearbox book and solar charger is now sold.
Stuff will start appearing on e-bay soon. Also got some other bits to list as well.
Full list of other parts for sale :-
Landrover Series I, II, III Haynes Restoration Manual - £10 + £2.95 P&P - Printed in 1992 good condition cover is a little dusty after being stored in the garage
Halfords 'Advanced' (Red) Anti-freeze concentrate - 5Ltrs (No post). Normally £20+ from Halfords. Never opened. £10
Ski fleece never worn or opened. In 'Large' Size £5 + P&P
Renault Laguna Washer Jets £10 Free P&P
x4 H3 100W Bulbs (never opened) £10 Free P&P
Landrover OEM Oil Filter RTC 3183 for the 6-cylinder Petrol engine - £6 Free P&P
Holts Cooling system flush - £3.50 Free P&P
interested in:
Corsa 'B' Rear spring height adjusters Brand new, a few scratches, but great condition £ 10.00 £ 2.99 £ 12.99
Any pics at all?
Might be worth keeping the first post up to date for those who dont want to read all the posts to see if what they want has been sold :)
Editted lists - also they are here
Plus my other for sale threads, with a 1.3 engine, gearbox, driveshafts & x5 steel 13" wheels.
Plus a few other bits i just remembered :-
- K11 Vacuum sensor; 4.99 Free P&P
- Facelift fuel rail with top feed injectors £25 Free P&P
- K11 Temp sensor - two wire grey plug 7.99 Free P&P
- K11 Water pump - Nissan item, no leaks. 7.99 Free P&P
- Coilpack cam cover in red, £10 no post
- K11 facelift gearbox speed sensor, £10 free P&P
