looking to turbo
Belly93
to turbo or new lump :/ hmmm
I'm looking to turbo my k11 its currently a 1.0l thinking of putting a 1.4 lump in, what will i need apart i know I'll need
Turbo , suggestions for 1.0l
Manifold,
Intercooler,
how do i control / change boost levels?
Oil feed / return
was thinking self vacuum for wastegate control
What would you recommend frank? I got the idea from looking at yours I thought that was vac opperated
something similar to a t2/25 is ideal, just look at what other small stock turbo'd cars are running e.g. Glanza V's use a ct9
the 1st one was vacuum, and i was trying to blow down it lol :D
and it depends what you,re after really, the little T15,s were manic instant boost, and ideal if you only revved to about 3k (ie, city driving), but they turned into a heatpump above 4k !
a bigger turbo gives a lot softer powerband, but they,re a hoot at 5k ish :)
Is that the one you had on at japfest?
aye, that,s the TD05, ex 300hp subaru wrx, so its probably only spinning at half speed, even when i,m running full chat :) the T15,s had a bit of shaft wear when i bought them, and got steadily worse, this one had (and still has) zero shaft wear
Write your reply...
