looking for more power from a k11
well lads new enough to this
I was just wondering is there any ways of getting more power from a k11 engine for hotrod racing??
I already have the limiter removed and the timig turned up to the last..
Also is getting a flywheel lightened and head skimmed worth the money or will it just damage the engine..
Thanks in advance ffor any help..Thats a picture of the car im using :)
you can easily get 80 hp then mate (checkout baguete,s 1.0 blog)
definately flywheel skim (to 4kg) definately headskim (at least 1.5mm) and 1.3 or race cams :)
Humphris of oxford is a good place, I got some springs there great advice, support and product!
they sell cams too and loads of other stuff... :)
But I'm sure frank will guide you to the best place rather than me
which cams did you go for frank? whats the difference in a regrind and the humphris one's?
i always assumed the race cams were longer
i use autosprint and piper ones mate, with extra shims underneath, matt,s cams are direct fit (stock single shim)
