Longer studs
MikeyRocks
I may need to get some longer studs so if any anyone can give me some help/advise on what stud length/diameter im going to need and where do buy them.
Would be much appreciated if someone can help.
I will only need the rears done if I get some longer studs :)
Size depends on what you wanna do with them. There is few sellers on eBay. The thread size woul be m12 x 1.25 and 14.3mm spline I think.
^ WHS.
There's a guide for fitting the rears in the guide section, and most of the info is in my LX blog. Fronts are dead easy, rears are a faff because of the drums brake mechs.
I had a slight issue with my generic studs in that the spline was too deep and extended out the mounting face of the hub flange. I just counter sunk the stud holes the rear of the discs and drums very slightly with a large drill bit.
^ WHS.
Thanks both for your help, Im going to deal with this later after Japfest is over
I'll just run 155's on all four wheels, Should give the rears abit of a tuck :)
