Lock barrell assistance.
CMF_bongo bus
Hi guys.
I'm currently trying to install a new steering column into my k11.
I have removed the old one but have realised that I need to install the lock barrell from the original steering column into the new column.
1. Does anyone have any experience in doing this?
2. If so how do I drill out the sheer screws to remove the lock barrell?
3. How do I refit the lock barrell onto the new steering column?
4. How do I re-aline the new steering assembly?
At this stage any assistance would be greatly appreciated.
Thanks in advance.
John.
CMF_Mimz
frank2 WROTE:
"bongo bus WROTE:<BR><BR>"Yes there is... I just wanted to make sure that it's the ok... Is there anything I should look at doing before I put the steering back together?"</DIV><BR><BR>has it got an airbag ?
Dont think there is any k11 with airbag in australia.
CMF_Micra_King
Mimz WROTE:
"frank2 WROTE:
"bongo bus WROTE:
"Yes there is... I just wanted to make sure that it's the ok... Is there anything I should look at doing before I put the steering back together?"</div>
has it got an airbag ?"</div>
Mine has an airbag. Never seen a Super S fitted with an airbag though.
bongo bus WROTE:
"Hi guys.
Thanks in advance.
John.
When I fitted a new ignition barrel I used a screw extractor to remove the shear bolts eg drill a small hole and use the extractor to un-screw them out.
