Little Red is up for sale
right the time has come for little red to go to a new home, i'm looking for £500
no tax but has mot till February....
body work is in very good nick for age (20yrs)
has done just over 100K with no hiccups no smoke or rattles
has new rear shocks got fronts but haven't fitted them (fronts will be included in sale)
right heres the bad points....
needs new springs all round
new front shocks fitting
new exhaust mid pipe to back box
headlight still needs sorting
and the reverse switch needs fixing
Shame that...
whats the chances you had a K10 now K11 work nights and same age as me? lol
Good luck with the sale!
Yeah, the cross-over adaptor is plugged into the the wiper motor. They only put that on the models with intermittant wipers fitted, it's a long story but to fit the int module you need to swap two wires over at the motor side, and thats what that big gray plug is for.
Have a look on the front panel behind the drivers side headlight, you should see a black box with "judecco" written on it. If not then it may have had the adaptor fitted by mistake. You can remove it and plug the black plug on the harness directly into the motor, and it'll work fine if you don't have int fitted.
