I think I messed up.. Working on my rear light (reverse light) I used a voltage meter, and accidentally I may have made a short circuit between the rear light and brake light in the left side. The result was a new fault. (I fixed the reverse light). Now in the rear left side the rear light does not work - however the brake light does. It is not the bulb - I have measured on the wire plugs after pulling it out of the lamp.
I switched new bulbs in the front position light (hope that is the right word - its the smal white bulb in the top of the headlamp). I noticed that in the left side I also do not have any power in the wire plug coming to the newly installed bulb.
Before I messed around I had a working left rear light, however, I don't know if the left position light worked before I possibly made the short circuit. Not sure therefore if the errors are connected, but I am thinking if there is a fuse (or two) somewhere I could change out.
I would be extremely thankful if anyone can point me in the right direction!?
Cheers,
Dane
Cheers,
Dane
