left indecator
Hi
new to this...... i have a Micra s and the left indicator is not working on the instrument panel, although it flashes on the outside of the car (nothing wrong with the right one), took bulb out but its OK, looked at fuses seems to be OK, does any one know whats the problem is and can you help
many thanks
Dashboard Indicator Warning Lamps DIY Repair: K12
Left turn tell-tale LED failure is one of many notorious electrical/electronic serial repeat failures on the K 12 Micra, necessitating complete LED display replacement or an improvised DIY repair.
Here’s a link to Silver Foxes cheap simple improvised DIY electrical repair guide of dashboard main beam and indicator tell-tale lamps. This avoids expensive parts replacements and disputes with MOT testing garages trying to maximise profits by creating unnecessarily expensive repair work for MOT”s. NB; The MOT tester can reject or refuse to issue MOT and the reason for rejection is that he cannot hear the audible sound, and the visual indicator LED is not working.
Follow the links and read all the posts from start to finish of each thread.
http://www.micra.org.uk/threads/indicator-tell-tale-light-on-dashboard-dead.46968/#post-487004
https://www.micra.org.uk/threads/faulty-turn-indicator-on-instrument-cluster.14283/#post-672190
