Hi all! I recently finished replacing the engine in our old K reg Micra K11 1.0 16 valve. All up and running perfectly with no problems apart from one... Bizzarely, the left hand light cluster is not working. The indicator works but the sidelight, dipped beam and full beam do nothing at all. I've swapped the bulbs over to check that they work and they are all fine in the other cluster. All fuses are fine, everything is plugged in etc... Any ideas what could be causing this to happen?
Any ideas appreciated, thanks!
Mike
Mike
