Leaking oil from oil pan
Hi,
My engine seems to be leaking oil from the timing belt side of the oil pan. I've replaced the half circle shaped seals several times now but it's still leaking from the same location. I wonder if oil can leak from the big end bearing, where the big end bearing meets the cylinder block? That area has no sealant and is not "regulated" by the half circle oil seals...
Any input appreciated!
