Hello!
I have a K12 Micra (59 reg). I am having an issue with a leak in the boot, on the passenger side.
I have changed the passenger side, rear indicator/brake light cluster - which hasn’t solved the issue. I have stripped the lining out of the boot, and used a hose pipe, to try to diagnose the problem. It seems that it is coming in through the top of the boot door, and then making its way behind the boot door and streams out from behind the rear light cluster (on the passenger side).
The only way that I could see it coming in is from the bendy-looking seal, that is above the gas-lift arms. Does anyone have any experience of this, and how to solve?
Thanks in advance.
Thanks in advance.
