Greetings to other K12 lovers from Micratec in Essex
For those of you with an early K12 and have retro fitted the facelift centre console (like me) and have or are going to fit a double din audio upgrade who like to keep things looking stock, the original 3.5mm aux socket connection (picture 1) can be replaced with this:
https://www.tme.eu/gb/details/usb.nissan.01/power-car-accessories/per-pic/c5701-usb/
I have seen similar connectors to this from Autoleads and Connects2 however I do not know if they are the same size as the original hole in the cup holder.
This USB and 3.5mm aux socket connection (picture 2) is a perfect fit, it is keyed and only fits in one way. As you can see the other end of the new cable has a 3.5mm plug and USB plug which go into the rear of most double din audio units, you just have to route the cable up to the back of the double din unit, you'll then have the aux and USB for audio and the USB for charging you phone.
Considerably less expensive than a genuine Nissan part from a Juke or Qashqai which wouldn't work anyway because they have the original loom connection.
