cisco
» CMF MemberHas anyone found that maybe a pulsar master cylinder is a straight swap in? Or had their micra one's valve largened?
I'm getting sick of the spongey pedal feel due to having the large AD22VF brakes installed with the factory master cylinder. As the pistons are much larger, the pedal has to move a lot more to inject the required amount of fluid.
A factory micra has a much firmer brake pedal feel.
If noone has done anything in this area, I'm going to see what some options might be soon. Really want to get that firm pedal feel.
Also going to get my ABS completely removed. I'm not running any front sensors any more since I installed the VLSD driveshafts, now the ABS light stays on. So today I will pull out its fuse so that goes away, but the unit and system is very heavy, so I want to remove the whole thing and gain a whole lot of clean engine bay room and weight saving.
