Larger injectors help !
CMF_frank2
only the GA15 (pink) or GA16 198cc (black) ones are a direct fit tinky, the CGA topfeed rail gives more options
CMF_frank2
Tinky WROTE:
"Thanks Frank your pic. answers a lot of questions! You should get a job taking pics. for Haynes (you do a better job) hahaha. Do u have to mod the CGA rail to fit? In Aust. what are the CGA toprails fitted to? Anyone know.
the CGA rail is a direct fit tinky, (apart from an idle control valve clash) you just need the alloy standoffs/spacers that go under the 2 bolts
CMF_frank2
the blue ones are from the CGA tinky, and mine pulls like a stock 1.0 with those in !
the red ones are from the QG15/18, but various other topfeed injectors fit apparently (volvo etc iirc)
CMF_deNs
LowMicra WROTE:
"CGA aren't common in australia but GA 16 are (n15pulsar)
Gumbi has one for sale
Not the GA16 that you want. Australian-delivered and even JDM GA16 injectors aren't a fit, from memory. UKDM GA16's are different again (198cc I think) and are the only GA16 injectors that'll fit in the standard CG13DE rail. You'll require more than that, since you'll need something to handle the extra fuelling.
---dens
