superls
K10 Tuner
Hi, just to give a bit of background to my question, i want to measure the afr in the exhaust.
righ onto my question.
i have a selection of lambda sensors and am a little confused to their wiring and operation.
ive done a bit or research on lambda sensors and understand the operating principle and how they work, but to be honest i was more confused after i looked into them, lol.
i have 4 sensors,
1, 1 wire one, the wire is green and is the one found on the k10 ss.
1, 3 wire one, 2 white wires and a black wire.
2, 4 wire ones, both with 3 white wires and 1 black wire.
now correct me if im wrong but they all do the same thing ultimately? during my research i discoveres that some have inbuilt heaters, and early ones didnt. leading me to believe the old one of my k10 ss is heaterless. and the 2 4 wite ones have heaters? if so does the 3 wire one have a heater? it was concluded from my research that a heated one is better.
so back to my main question how do you wire them up? the black wite is the signal out and the white ones are the heater? or am i wrong.
also i read franks blogg (i think) and he says he connected a voltmeter to his so he could read the afr, but what scale do lambda sensors operate to and what is the corresponding afr?
sorry if ive confused you, cheers in advance for any answers.
superls
i have 4 sensors,
superls
