My lambda was tested in its recent MOT. the results are causing me problems.
we have the following:
1st test - limit allowed - actual values - results
engine RPM: - 2450/3050 - manual check - pass
CO % VOL - 0.20 - 0.00 - pass
HC ppm VOL - 200 - 18 - pass
lambda - 0.97 to 1.03 - 1.98 - fail
2nd test
engine rpm - 2450/3050 - manual check - pass
HC ppm VOL - 200 - 28 - pass
lambda - 0.97 to 1.03- 2.04 - fail
natural idle test
CO % VOL - 0.30 - 0.00 - pass
what is the lambda test, and why, when my CO and HC levels are so low, is it double its specified limit........ its such a confusion.
more to the point, what is the failed point in the system. during the test i had no back box and no air filter. fuel pressure standard with 2.2mm gap bosch super 4s.
2nd test
natural idle test
