KYB Excel G gas shocks part numbers and availability
Hi, I've been trying to find the part numbers for the KYB Excel G gas shocks for the K10...
The rears are the same unit each side and I believe that the part number is 341056.
I can only find 'right' front units available. Part number 332060.
Does anyone know if the fronts are the same both sides or does anyone have the part number for the 'left' front?
Cheers.
Cheers.
Generally front shocks are exactly the same, bar the brake pipe bracket being in a different place left and right. For example, on micras the brake pipe bracket is on the front side of the shock as the caliper is towards the front of the car. Other than that, there's no difference
Hi Liam, I was hoping that would be the case. I will likely just order two 'rights' and see how I get on.
Cheers.
I got the KYB Excel G gas shocks on yesterday with 35mm Pi lowering springs. She's handles much better now. ??
... it could still do with an anti roll bar though!
