Knocking on Pull Away/Cornering
hoodedreeper
I've got a knocking noise when i pull away,its a single knock (nothing continuous). It also does it when i corner at lower speeds,also if i'm stationary with the handbrake on,and i raise the clutch just past biting point (so the car dips)
I thought it was top mounts,but it doesnt do it over bumps
Thoughts?
Check for play in suspension components, ie ball joints, stabilizer links track rod ends. Inner track rods etc :)
check rear mount through-bolt. i once forgot to tighten mine and gave the same symptom especially when i was about to reverse.
i have the same problem but it happens also when going over bumps etc, and ive just changed both cv joints :/, i was thinking it could be my anti roll bars hitting the body coz ive lowwered it? :/
