i checked cv boot and joint they look fine but its still tappin on left when turning brake disk has play in it in sounds li9ke its that any ideas anyone
I have this too, when turning right. It's a single sometime double click/knock that sounds like it goes up through the coil spring...
I had it checked out and the lower control arm bushes on the right side of the car are worn. It also is causing a big clunk over the occasional bump. Check all the bushes, I need to replace a whole lot on the back end too due to similar knocks over bumps and turns.
