Hi all,
Another noise has decided to manifest itself into my 1998 Equation. This time it's a clunk that often occurs when I accelerate quickly, brake quickly or turn right quickly. I'm struck between it being either my front springs (both are rather corroded), My CV joints (The service history says that some were replaced in 2013 I'm unsure as to whether they all were) and my sagging drivers door.
I initially thought my drivers door was causing this as I propped up my door with a plank of wood (As recommended by a post on this site). The first time I tried this the noise vanished and then started again after 3 days. I repeated the process but made sure that the door was properly propped up as much as possible and left it for around 4 hours and this morning it's still making noise and the door is still sagging.
What should I do? Should I get my springs changed or is there a way of stopping the door sagging?
