They are a replaceable item they don't last very long I have seen guides were people replace these.
Also one guide they replaced the switch inside.
Mine is the other type that's under the handle it has worked fine for the time I've owned the vehicle.
The last few time I have opened the boot though it seemed to be delayed may be this is before they actually give up and you must replace..
Good luck with this
I
Sent from my ASUS_T00P using Micra Sports Club mobile app
So, I checked out both switches; the unlock button and the boot release button with a multi-meter and both work; good start, but does mean the problem's elsewhere. I popped off the rubber boot covering between the body and tailgate and "ta-da", someone's been here before (and not left it looking to pretty)! Not spent too much time tearing it apart yet. No problem removing wiring from the tailgate, but there's not a lot of slack in the body. Anyone know where there's decent access to these wires in the body?The other way is to swap the unit and place the preface one instead.
I think max attack has a guide to this way and it might be a better guide..
Nice work on the loom I admire your patience and efforts. Great idea to label the wires also.Work in progress... With 3 pairs of broken wires (all the same colour) figuring what's what wasn't straightforward; a bit of a ?'in ! But, everything works again (properly); wiper doesn't stop in the middle any more (and now we've even got intermittent! ?) and the unlock button works . All cables (bar the heater element wire) had previously been repaired (poorly), so time well spent. Need more heat shrink, finished hopefully tomorrow (without the need for 5 rolls of insulation tape).
