Hi there last week I bought a key fog from eBay because I've got only one key for my micra incase if I lost it. My question is if I program the new key fog is it work together? Or it can remember only one I'm scared about incase it forget the original one
they should both work still when you get the other one programmed
I don't see why it wouldn't ^_^
My car still has both originals and both work fine.
I have noticed that if you set a fob for "Anti-hijack" mode and the other was used in last "convenience" mode it will still be in convenience mode, which is odd as I thought that kind of setting was to do with the car, not the fob
I guess if you're worried about one not working when the other is programmed just double check them before you leave wherever you're getting the fob programmed
