I have owned a Micra (2002) for many years but always manually unlocked/locked with the key, despite having in possession the key fob. I don't recall if it ever worked or how it stopped working.
Just recently, I figured I would try getting the key fob to work again.
My first step was to change the battery on the fob. Next, I searched around for the correct process to reprogramme/pair the fob with the car (0 to ON position six times, etc). The car seems to enter programmable mode, but the car does not respond to controls from the fob.
I'm unsure if this means the fob is damaged (apart from the buttons being worn, which are able to be pressed in) in some way internally.
Various places offer uncut key fobs which the seller claims only need to be reprogrammed (is this the same as the standard process I have described above?).
Can anyone advise? Thanks
