needing help to remove ac system
aye jimmy any help would be appreciated as i intend to keep the car on the road as long as possible done lots of wee jobs getting to like the car
engine cutting out when air con switched on feon reading in danger zone anyone got any ideas why
You may want to check your electrical system properly first to make sure your alternator is up to scratch, should be no other reason I can think of for it cutting out just because you switch A/C on.engine cutting out when air con switched on feon reading in danger zone anyone got any ideas why
If that does not show any defects then you will need a shorter belt so you can just bypass the A/C pump. Take a measurement of your current belt and then use some simple measurements to guestimate the size of the new belt you will need. Never bypassed A/C pump on a Micra but have done on other vehicles.
