I write over year ago some where (?) here forum about my K12 turbo Micra project. Long time have gone of last writing so I can`t even find that thread. So now new one only for this Turbo K12 project.
Here is few new videos:
Around walk:
Acceleration of very ice and slippery road:
After 2022 when one piston melted because of knocking I remove gen1. HR16DE engine. I change newer version (gen 2.) of HR16DE engine. Gen 2. is with two fuel injector per cylinder, oil cooled pistons and also variable exhaust valve timing. I locked that ex. timing because in original HR16DE gen1. ECU system control only intake valve timing. Exhaust cam timing is one tooth beside of original marks.
Major change year 2023 was new turbo. Old turbo was from Renault H4Jt TCe 1.4 130hp engine. It was low pressure turbo and with full throttle at 5th gear over boost was not max. 0,50bar. Ie turbo stall with that situation and cause that pressure goes up and down. Now new turbo is from Nissan Juke MR16DDT engine. It can keep with full throttle max over boost 0,55bar steady. I have driven only ice slippery roads but I`m sure that there is lot more power in high rpm! Let see how it works summer time. My daily driven car broken now in winter so thats why I have driven this turbo-Micra few weeks.
Around walk:
