K12 Stiff Steering
I have just resurrected my dads Micra K12 1.4 Techna which has been stood for two years and only has 24k on the clock.
Surprisingly it sailed through an MOT only needing two windscreen wipers and the service didn’t show anything major.
Although it runs and starts fine but the steering is awful being really stiff and if you turn the wheel to the left or right it doesn’t return to the centre and you manually have to do it. Not sure if this is right as it’s a 2009 plate and I’m driving a 72 plate Seat.
The journey south from Nottingham when I brought it home was an experience, but there was no wheel wobble or unusual noises. I had four new tyres fitted and tracking done before the journey so hoped it would be fine.
I’ve done a bit of research and saw the issue with the PS system so borrowed an OBD reader but no codes were found.
I haven’t had any chance to look any further so thought a post in this forum may give some ideas as where to look next, as my daughter is desperate to go learner driving
Thanks Neil
Is the PS light lit on the dash? A cheap reader won't be able to access the EPS module, hence no codes. If you're anywhere near Lincoln I can read and reset them as a quick fix for you - I'm not a mechanic so my services are free
The PS isn’t on permanently only on start up then goes off. I must admit I did think about cheap OBD readers so I’ve managed to find a garage that says they are independent Nissan specialist so got it booked in to see.
Thanks for the offer and reply much appreciated
Hmm Interesting, It sounds like you got fault on power steering. (Obviously Bubba)
I am sure someone here will provide a link on this website as there is a lot of posts on here on this very subject.
If this is your fault you have this might turn out to be on the expensive side.
I'm not saying this is your problem being something to do with the steering column.
But would be interested to know what this Nissan Specialist tells you and what price they charge to fix the fault.
There are a few on here that know this system very well and better than I do.
Keep us updated we all help each other where possible.
Good luck... :)
