Hi
Last Friday I purchased a 2003 K12 with 64k miles. Has almost FSH and one previous owner.
The following couple of days the car started easily although I did notice a slightly lumpy idle until the engine warmed up. On the third day I went to start it from cold but couldn't. The engine turned over easily but didn't quite seem to catch and get going. It was almost as though it need a bit more choke. On return from work I managed to get it started, warmed it up then turned the engine off. Went to restart it again and got the same problem but got it going eventually.
The following day it started from cold first time with the same slightly lumpy idle.
The garage have had it two days and said it keeps coming with camshaft error messages and tried 3 replacement sensors. They've also noticed the wire around the ecu have been disturbed and the EML bulb is missing. The garage are talking about get the ecu checked for £60. I have read about timing chain but mine makes no noise at all, in fact it's very quiet.
Any advice?
Any advice?
