Hi guys! Happy New Year to all off you!
I've seen that this topic has been discussed previously, but it seems that my case is a bit different.
I just purchased a 2009 Nissan March (imported from Japan). The stalk has three positions -> OFF, Sidelights and Headlights. Now, when I turn it to the second position (headlights) it goes to high beam and it stays there no-matter if I change to low beam or flick it. Of course the blue indicator light in the dash is on.
I was reading all the threads I could find here regarding the melted connectors, blown fuses, oxidation, relays, faulty stalk and grounding problems.
It seems to be a difference on my car as it is fitted with H11 bulbs and not the H4 you are all referring to. After checking both of them they are as good as new. No signs of melt, humidity or oxidation. It was a bit tricky to open the bulbs cap, but after doing so, I am telling you they are in really good condition.
Next I checked the fuses and relays. Mine are fitted below the left hand side headlight. I had to remove it prior to accessing that box (still wondering why the Japanese did that). Again, everything in perfect condition! I checked the fuses and could hear the relays clicking.
Next on to the stalk. I removed it, disassemble it to check the contacts condition and verify with a multimeter. That as well, was in really good condition and the contacts were working properly.
I believe that what is left (according to previous threads is the grounding). Not sure what to check though.
Keep in mind that even the car is almost 13 years old it only has 45000 km on it (around 28000 miles). Further, I live in Cyprus where the weather is mostly hot and dry. I am not sure if that information helps but I am giving it anyway!!!
Regards Andreas
Regards Andreas
