K12 sideskirt length
It is ~1735mm at the top. They are quite shaped around the front wing so you might need to modify a bit even if the length is correct
T
It is ~1735mm at the top. They are quite shaped around there front wing so you might need to modify a bit even if the length is correct
Thanks for that, I will have a measure up soon.
