This subject may have been covered before however has anybody actually completed the job, rear drums on any car perform perfectly adequately however they just look awful.
My research leads me to believe that it is a relatively easy swap over in terms of fitting the rear beam axle from a Clio onto a Micra as the parts from both cars are essentially the same with some differences only in the brake lines and the issue with the ABS sensor, is this correct, has anyone done this conversion?
I've heard an alternative is to use the disc brake stub axles from a suitably equipped Clio which apparently also physically fit on a Micra, can anyone confirm this either way?
