K12 power windows fault
Got a 2008 K12 with the power windows not working. Driver side switch and passenger side switch not working. Does anyone know which fuse/relay I can check, or is there something else I can check.. Thank you!
The fuses for interior usually found in the fuse box at side of steering wheel.
They are labeled on the cover..
Here is a link for you
This should help locate all the fuses on the vehicle
Does the switch on the passenger door work? If it does it might be the wiring that passes through the gaiter between the drivers door and the pillar. They have a habit of breaking because of the constant use of the drivers door. I've repaired several makes of car with this problem before. Hope this helps. Steve.
