Hello All,
I recently purchased a K12 2003 1.2 ltr S, The car was bought on a total whim and had numerous issues... the engine sounds beautiful however some faults with sensors etc. please read below for explanation.
So I bought a diagnostic reader and various codes came up, all faults have now been removed. The following has been done;
Camshaft sensor
MAF sensor
crankshaft sensor
Oil change and new filter
new air filter
new inlet manifold seals and upper packing and airbox seal
Throttle body change
The code initially that wouldn't go was P1171
so checked all hoses for leaks etc, hence the replacement of the seals on inlet manifold. Then resorted to the throttle body replacement.
Ive noticed the engine management light is not working... It doesnt light up when ignition is on. I have removed the casing and checked the wiring and all seems good there - there is no bulb to replace for the location of the engine management light? that is issue number one? How can I get that checked/replaced please?
So now there are no fault codes on the diagnostic - I have tried to calibrate the throttle position sensor as advised on previous groups however no avail as the car is running jumpy on idle and loosing power - below 1000 revs and dies unless prompted with the accelerator. However the car now isnt limited - previously it was limited to 3000 revs I believe due to the throttle body.
Can anyone post a link for the calibration of the throttle body specifically for a k12 or is there something that I am missing ?
Im a complete novice and im really falling in love with my car as im working on her but im scratching my head now with the jumpy idle/stalling - low revs and no fault codes so not sure where else to look...
Thank you for anyone who takes the time to read and respond,
Jas
Camshaft sensor
MAF sensor
crankshaft sensor
new air filter
Jas
