Hi! :grinning:
My girlfriends K12 Micra had an intermittant fault with the wipers randomly coming on. This happened first a few weeks ago. She only uses the car at weekends and some evenings and this happened a few times but not every time the car was used. The washers worked fine at this point.
Last time she used the car she found out that the washers were not working (front or back). There was no noise from the pump motor either but the wipers did kick in when the washer functions were tried (stalk held pushed back or forward for few seconds)
So last night i took the arch liner off and part of the bumper to check the connections where on the washer pump, which they were.
So then i removed the washer pump and hooked a 12v feed to it and nothing happened, other than some of the multiple times i tried it, it made a small spark and the unit got warm. It seems the pump motor has burnt out and shorting.
As i didnt have a multi meter handy i couldnt check that the wires that i disconnected from the pump were live but i suspect these are ok and its the pump motor thats dud.
In the back of my mind im thinking maybe the earlier wiper fault was caused by the faulty pump shorting and causing the auto wipe function to kick in. Other than that i suppose there could be another separate cause of the wiper fault and that has caused the washer pump to burn out!
Two questions for you guys really:
Has any other K12 owner had a similar problem and if possible how did they solve it?
Any ideas where i can aquire a washer pump from at a decent price (maybe online factor?) cos i couldnt find any for this later model listed on ebay?
Many thanks, Tom
Many thanks, Tom
