Planning to lower my k12 by 35-40mm any reccomeneded springs, that have worked for you guys?
Thanks! How much clearance do you have from the wheel and the fender?I have those => Eibach Pro-Kit Federn für Tieferlegung NISSAN MICRA III http://www.ebay.de/itm/Eibach-Pro-Kit-Federn-fuer-Tieferlegung-NISSAN-MICRA-III-/141952178845? . For SR160 lowering is 25-30mm, that's low enough for me on Finnish roads and speed bumps with 16" wheels. I don't need to dramatically slow down when driving to drive ways/yard roads and no rubbing to inner fenders
Here is already thread with almost same issue:
LOWERING => https://www.micra.org.uk/threads/lowering.67778/
Thanks! Where did you buy the window wing gaurds?Hello Cameron,
With 185/50-16 tires, diameter 591mm, clearance is ~45mm. Hopefully this helps you
-Mika-
Looking good Mika. Just checked my standard Sport + (with the same size wheels and tyres as your SR) and tyre top to wheel arch is around 90mm! When you put the shorter springs in yours did you fit shorter rear dampers? I'm mildly concerned with the shorter springs being unseated from the lower support, on full re-bound, if the travel of the suspension isn't reduced at the same time as fitting shorter springs............Hello Cameron,
-Mika-
John, where in dampers these bands are located? Are they visible without tearing anything to parts?If you have fitted 20-30mm lowering springs in yours Mika, then I suspect that your SR, if it was factory fitted with the optional 'Sport' suspension, was 25mm or so lower than the Sport + as standard........The factory fitted 'Sports' suspension would have purple band marked dampers, as opposed to blue band marked ones, what are yours? Other than stiffer than standard, perhaps the Sports suspension rear dampers are shorter than standard as well?
Hi Mika,When I get home I will check original springs
