K12 coil pack into K11 engine?
Hi,
I am fed up a bit with K11's ignition, the rotor and the HT contacts looks awful in my car's distributor. I wonder is it possible to fit physically a K12 coil (built in the spark plug connector) into a K11 engine? The electronics is a secondary problem, I think I could DIY it but if anyone already have a solution i am curious to hear about it.
The later k11's came with coil pack engines
afaik you need to swap... Engine, engine wiring loom, ecu, everything to do with nats and possible more
