My dad's '04 K12 Power steering stopped working a month ago. At the time he had a scan done and the codes were reset. It worked for a week an the fault came back. (From Consult II the faults were (relating to power steering): motor fault and control unit fault. Called Nissan and got the relevant part number for the entire steering unit ( 44810-AX003) as neither just the motor or control unit could be replaced or serviced (according to Nissan). The cost new for this part is 1759.00 vat inclusive...ouch!! no way !
Well, the new part was not an option, so we got a mechanic to remove the unit, took it to an electrician friend who serviced the motor and control unit (so much for Nissan saying it can't be serviced) The electrician re soldered all parts in the unit that could be soldered and that was it.
The unit was replaced, the Consult II was used to re scan and clear the codes (note that the engineer (who works for Nissan) indicated that due to the wiring set up on the Micra, fault codes trickle to many other parts of the car at the same time) so many codes had to be reset!
All working fine now , approx. one month later.
I'm posting this as a possible fix to anyone else who may encounter PS problems.
