So, we have a misfire (usually comes up on the fault code reader as P0303 generic misfire on cylinder 3.)
Originally, I thought, coil or spark plug, so I replaced all the spark plugs, and the coil for cylinder 3. And, that seemed to fix it. For a week or two.
Then it came back. So I replaced ALL the remaining coils. Nope. Took it to a garage, and they spent hours trying to figure out what was wrong with it, replaced the crank sensor, and eventually said that when they plugged it into an oscilloscope on cylinder 3, after a bit it wouldn't pull to ground (and I googled, this is a common fault on that ECU). So, I found a company that fixes those ECU's, sent it off and.... No fault found. They had opened it up (as evidenced by the mangled screws and extra sealant everywhere), so they did look. So, I put it all back together today, hoping that maybe some pixies had magically fixed it, and after getting over the stupid immobiliser reset procedure, eventually got it started, and within a minute, it was back misfiring.
So, anyone any ideas? Getting more than a little bit fed up with it if I'm honest.... (Wife loves it, I currently very much don't.... )
