Hey,
I recently bought a 53 plate 1.2S Micra and the Airbag warning light has started flashing.
I put it into a garage today for them to do it under warranty, but their diagnostic machine isn't compatible - they say that only a main Nissan dealer or a Nissan specialist will have a compatible diagnostic machine - does anyone know whether this is the case or not?
Also, is this a common problem? I've heard that simply moving the seat back and forward can cause the wires to be moved/damaged and cause it to flash?
I'm getting my car back tomorrow morning to will fiddle with the chair/wires under it, see if I can get the light to stop flashing, but has anyone else had this same problem? What did you do about it? The main problem is that my warranty apparently doesn't cover diagnostics & testing, so it only covers the actual work done to fix it, which is a pain.
Cheers.
Cheers.
