Hi there,
My friend owns a 1.2 k12 10 plate it's been stood for around 3 months and she decided to move it, the car started up first time but as she was moving the car it literally cut out, the car was completely dead except for the fact the lights work and the immobilizer light is blinking on the dash, when turning the ignition nothing happens at all, you also cannot lock the car when pressing the key buttons the dash indicator lights flash once but it won't lock or unlock. I have tried disconnecting the battery for half hour but that makes no difference it has the same symptoms and I've also tried jump starting the car but still nothing. The battery appears to be fine so I'm lost to what the issue could be. When turning the key there's literally nothing on the cluster's other than the red car with the key blinking.
Thank you for reading
