Hi guy.
I have a Micra k12 1.0 2003.
I have an issues with the car it is losing oil i have checked for oil leaks around the engine i even pressure washed the engine had another look under and over jacket up the car the full lot not one oil leak .
took off the throttle body plastic part i saw oil in the intake manifold
took out the spark plugs no oil on all 4 plugs
Did a head gasket check came back blue so all is good
I'm starting to think its valve seals ????
I lost 1L of oil over two weeks
as anyone came across this before
