K11 wont start after cutting out
Hi my micra is not starting changed the fuel filter. Checked fuses in car and engine bay.
Poured fuel down filter compartment and still nothing. Any ideas
Right the diagnostic says that s it's the immobilizer. Any idea if I can drop it out and not have one or any idea how we can fix it.
New diagnostic said it was the key or the immobilizer receiver.
Tested the and the signal was fine.
Had key and car reprogrammed and car started.
Took battery off charged it up put it back on this morning and it won't start.
Any ideas
Any ideas
It might be messy, but you're better off without the immobiliser as things stand, as otherwise you're going to be pouring money just for programming as the car itself might be super fine. just its security isn't
You can't disable the immobiliser on the coilpack ecu. I'd check the cam and crank sensor as the ecu won't tell it to spark without an rpm signal from the crank.
Sent from my WAS-LX1A using Tapatalk
