Common problem it seems.
The squeak is often not the wipers themselves (even though it sounds like it is) the cause is the mechanism.
Fix:
Remove the plastic scuttle under the window with bonnet raised.
Locate and grease all moving parts of the wiper mechanism.
WD40 will last about a year or so. Grease will last a LOT longer.
Disconnect battery during greasing to avoid nasty accidents. (Y)
Andrew
Fix:
Andrew
